Frigidaire A/C FAM18HR2A
appl.tech.29501
Here's the delima.....I need a display board for this unit which all breakdowns says is a part# 5304459473 even Frigidaire tech. line verified the #. this unit is a heat / cool unit and the board that comes with the above part # is different from the orginal. It doesn't have the red LED for the heat mode and the wire configeration is completely different, it will hook up to the harness and power the unit up but will not let you operate the heating. Tech line says they don't know what to tell me.....go figure :shock:
anyone ever run into this particular problem?
  • Replies 7
According to the breakdown I just looked at, there are 2 PC boards, the one you've already mentioned, and also # 5304459460. The one you already mentioned is for A/C,  the 5304459460 is for the heat.
the 9460 is the main control board not the display control.
It sounds like maybe the board you received was mispackaged.
The only place that had a picture is RepairClinic and it sure appears to me to have the "RED" heat led.
Looks like, a total of 8 L.E.D.'s, (6 green, 1 red, 1 yellow).
OEM part# 5304459473
CLICK on the above image to order.
Thanks for the reply, for some reason I couldn't find that picture. I was suspecting a packaging issue, will check on it Monday, thanks again.
So then, I take it that the picture looks like the board you expected to receive when you ordered part# 5304459473 but you infact received something different then pictured in a box marked with part# 5304459473?
that is correct
reordered part and it came in correct this time.....all is well.
