kit-aid rang #kerc607hbs3 discontinued
OAR
just need some lititure on this model #kerc607hbs3 rang...Thanks..
  • Replies 10
Thanks Pegi, thats exatly what I wanted but i did'nt see a proceedure for calibrating oven temps. Is that possible on this unit? It seems to run aprox 25deg. on the cool side of selection.
Should say in that tech sheet or the users manual, WP does not show the users manual available on-line, see if the owner has it....if it does not show a way to do this may just have to adjust the temps accordingly or replace the ccntrol....my WP range runs 50 degrees too hot so I just adjust the t-stat lower but that is fine for me, might not be for others..
The typical procedure is to turn on the bake function and then press and hold the bake key for 5 seconds. The display will change and you can input the temp adjustment, up or down, using the temp up and down arrow keys. This typical-- the user's manual will have the specific procedure, as Pegi said.
no owners manual avail. I'll keep searching on line...Thanks Pegi!!!!
thanks to you as well sensi...I'll try that as well
See if this procedure works (see attachment).
ka-oven-temp-calibration.pdf
BTW, I found the entire users manual. Like all users manuals, it's pretty fluffy but, boop, there it is! :cool:
Wow, how did you find it??  Cool....:P
Let's just say it's nice to have well-placed connections within the corporate labyrinth. That and entering the model number at the Kitchenaid site. :groucho:
