Maytag D/W mod# MWU7400AAX
profix
:? Going to work on a Maytag dishwasher, tried to find info with this mod #,and had no luck. Does anyone have info? May not be a correct number, wont be the first!
  • Replies 8
Not finding anything on that one, either. It's probably something not quite right with the model number.
What's the problem with the machine?
The owner said, the machine was making a load noise, even when empty. Hope I have the right parts before I get their. Sound like a problem in the pump assembly.
Get the correct model number when you go out and post it here so we can get more info on the dishwasher.
Sounds like you may just find a peach pit or something stuck in the pump.
Hey, thanks for your reply I'll get the correct info.
That's an easy one for a Maytag Factory Service veteran like me, the M at the beginning of the model number should be a D.  Problem Soved!:D
It should be DWU7400AAX.:)
Domo, Sublime Master STW! :dude:
Profix, here's the service manual for this dishwasher. A little light reading for you before you go to bed tonight. ;)
Thanks, I'm glad to be part of this forum where members help others instead knocking each other.( Thanks Scotthewolf)
