Bearing kit for the mah3000aww
fixit guy
Does anyone know the part number for the bearing kit for this washer? The kit I am looking for  does not include the outer tub.
Fix it Guy
  • Replies 7
The only bearing kit I can find is the one with the outer tub, I will check tomorrow when I get to work, but I think it's no longer available seperately
I found this Maytag number  12002022.  I think it is correct but not sure.  Says it is a seal kit but photos show bearing also.
It looks like a bearing, but it's not. There are 2 seals in that kit.
Appl. Tech, I do believe that you are correct.  I thought that I recieved a bullitin from Maytag awhile back with a bearing kit but can't  find it.
I couldn't find a bulletin on this but I did find these depressing words straight from the service manual.
[align=left]BEARINGS[/align]
[align=left]The bearings are not repairable or replaceable.[/align]
[align=left]Replacement of the complete outer tub assembly[/align]
is required.
That's not what fixit-guy is looking for. There was a link to a tool that you could use to remove and reinstall new bearings in the rear tub shell without replacing the whole thing, it also had links to bearings.
I still can't find the one I know I've seen somewhere in this forum, but did find this one: http://beesmart-ezway.com/for_maytag_1.htm
Actually that might be the link, here's the forum discussion where someone used the kit from this company: http://www.applianceguru.com/forum2/11277.html
