Frigidair wall oven schematic needed..help...m#cpeb30s8cc0
Rocket Appliance
[align=center]Bansia!
Does anyone have a schematic for this one?M#cpeb30s8cco (canadian model) I think its a relay problem,..but not sure how to check the relays,...I used to know how to but....old age and not enough brew made me forget...lol..:D
P.S. I just joined the "live help" with the Xdrive stash...WOW:dude: what a stash! worth every canadian peso I paid!!!!
Thanks again! Its not Rocket science....its Rocket Appliance!
[/align][align=center]
[/align]
  • Replies 12
is this model close enough ? CPEB30S9DC2 wiring diagram
right-click "Save Target as..." jpg
Thanks guys looks to be the same....I think I will replace the relay...can any one tell me how to test a relay?...Im a little rusty...
Thanks again...
  Rocket...
which relay ?
if you want to test the bake/convection relay just ohm check between e6 and e7 on the eoc with the power off, you should get 60ish ohms(bake and broil in seriesalso an easy way to test both elements without pulling them
yellow to black on the relay are the normally closd so shoud have contiuity
Thanks burnt toast.,....that makes it alot clearer!!...that seems to be the problem I guess....its gotta be that relay...I think...lol...Did I mention that broil  still works?..
Ill post tomorrow to let ya know ...
Thanks again...
Well......I checked all the relays like you suggested Brnt Toast....they all checked out good???...Elements check perfect (ohm value) the broil works on the wall oven and the convection fan works....getting continuity on all the wires leading to and from the relays and board....
Tell me what you guys think of this.....all the big relays check fine (relays NOT mounted on the board) I think its the bake relay that is on the board that is not easily removed without some good soldering skills..thats not me...lol... I took a chance and ordered a new board...
Hope it works!...lol...
Thanks for the help
Rocket.
most boards I deal with are the GE variety from Kenmore or GE... on those when energized the relay will click (as most do) then you are able to check it with your meter to see if it's throwing power or not...I must admit that most of the Friggys burn so bad there is no question of whether good or bad
If the elements check good and the tests toast offered up wee ok then really your last option was the board...I hate to guess but as sometimes ya gotta go with the gut...good  luck
Thanks,... ya I hate to guess as well,... but like you said sometimes you have to...lol..
Ill post tomorrow and let ya know..
I prefer the SWAG method when it comes to guessing.............Scientific Wild @$$ Guess !:thumbsup: Works lot'sa times when nothin' else does. LOL
to test the bake relay on the board jumper e9 to e7
also a volt reading between these 2 while the oven is in bake will be 240v if the relay is open
Well....Burnt Toast,... I did your test as suggested and it was open....I put the new board in and it worked...Thanks to ALL who helped me out on this one. I was a little nervous going and buying the board,.just in case it was not the problem but the checks you guys suggested confirmed my suspicions.....It was the relay mounted on the board that was bad!  No visual  signs of trouble but it tested bad....
Thanks again!......Rocket
