Kitchen Aid dishwasher m#kuds01flss6 flashing clean light??
Rocket Appliance
Ive got this dishwasher and the customer says "it wont do anything,... just flashes the clean light...."
I went to check out the problem and took the bottom panel off and to my suprise and my luck the schematic is missing!!!...lol..this keeps happening to me,...missing schematic!!!...I seem to be getting a lot of K/A stuff lately that is new just out of warranty?...
Im sad to say that I dont know where to start....I pulled the D/W out and did some checks but its hard without the schematic to tell what stuff should read...ie; thermistor,element,ect...I found what I think may be a turbidity sensor? its located right inline with the drain line and it reads "open"  as I said I dont know if it should be open or what because Im missing the schematic...grrrrr...
Any help or tips would be great guys and Gals thanks again,...
  Rocket.
  • Replies 10
Thanks Pegi...Is the little part I found by the drain a turbidity sensor? should it be open?
The sensor (pressure,turbidity) should be open....I found it in the tech sheet,...thanks to Pegi!.....lol....
Rocket, this is usually either a problem in the heater circuit or the motor pump assembly. The board is looking for a temperature rise in the water. It won't see if 1) the heater isn't working 2) the water isn't circulating over the heater. More details in this post:
http://fixitnow.com/wp/2007/01/20/blinking-clean-light-on-whirlpool-built-dishwashers/
Hey Pegi.....If the tco thermal fuse (in the heater strip circuit diagram) is open will that cause the blinking light problem? I know from experience with other  Kit aid when the tco goes out the unit is completely dead.....is that the case with this one or not...I cant figure this one out all the components  test fine ie; thermistor, turbidity,element and high limit?????....
I guess Ill put it into "diagnosis cycle service feature" and see what happens...just lost at this point:(
Thanks Master....lol...I must have been writing while you posted that for me...Ill check it out....
I really appreciate  all the help you  guys  and Gals  (Pegi);) Have been given me Im just a young grasshopper trying to service 50,000 people with only 5 service (2 other company's)  people in my area (HUGE shortage) and you have to take a $70 ferry ride to get here! No one from out of town will come here..lol..
Ill post back with a update soon!...
One more question....this model has no buttons accessible  when the door is closed  how do I rapid advance threw the cycles?
build a reaching stick that fits under the counter  :P
[align=center]They really think of the tech eh?!...lol...Good idea..thanks Burnt Toast
  .Rocket.
[/align]
