Bake ignitor replacement on Kenmore Elite m#7907921330
Rocket Appliance
Hello all!
I'm trying to fix a Kenmore Elite gas range,...no bake condition...broil works fine....I located the bake igniter and tested it 1.3 amps... its bad right? should be 3.2-3.6 amps if I'm correct,...
The problem I'm having is probably really simple one for you gurus out there..lol..I  slide the range out a little and took the back cover off...well the broil igniter was visible on the back side (ie ; wires,plug connector ect..) but the bake igniter wires are not visible...so  when I tested the  Bake igniter I had to test and locate it by taking the racks out of the oven, then I took the bottom panel out two flat head screws, which exposed the  burner plate I guess you could call it,...I removed the burner plate (very thick piece of metal) which exposed the burner and igniter,...I was able to remove the two 1/4" screws that hold the igniter in place and pull just enough slack to get my Amprobe on there giving me the low amp reading of 1.3 amps....My problem now is how do I get at the plug connection for the igniter??... Do I have to remove more panels or the burner?...
I remember seeing a visual guide on this somewhere on the forum but I cant find it now of course,...lol..
Im such a rookie eh?...well you gotta learn somehow...lol..
Thanks for your help guys and gals,...
Rocket.
Pull out the storage drawer and you should have access to the rest of the wiring & connectors at the oven valve.
Here is a picture...
Thankyou.....hvacdrd.....that makes things alot easier!!
Rocket.
