Click here to take the quiz.
Maytag Washer Model No. LAT9206BAM
John E. Hoagland
I am having trouble removing the tub nut from this washer.  I have a spanner wrench and have hammered on it as hard as I can but the nut won't budge.  I am assuming it is a left hand threaded nut.  Somebody, please let me know if it is OK to apply heat to the nut and if I would harm something by doing so.  Thank you for your help.
Regards,
John
  • Replies 5
[align=left]From the service manual:[/align]
[align=left]Use spanner wrench to remove clamping nut. This is a left-hand thread so it must be turned clockwise.[/align]
[align=left]A mallet will be required to loosen the nut. Use care when striking wrench to prevent chipping the tub.[/align]
And after you have got tired of beating on it and it still not loose, time for the chisel and a new stem seal kit.
Those nuts break off pretty easily with a chisel if you have to go that route.
The book says a mallet will be required to strike the wrench and loosen the nut.  Well a 2 lb ball peen mallet and copius amounts of Rust Buster and a severe beating of the wrench finally broke the nut loose.
lol, obviously the people that wrote the manual have never tried to remove one of those nuts cause a mallet aint gonna get it :D
Or maybe that manual was written back when none of those nuts had yet rusted stiff? Reminds me of the Ford Fiesta repair manual from 1985 that I once upon a time had to read... :D
