Frigidaire Model# FTF-2140ES0
Waneewek
Are these the same board?  If not, where is the speed control board?
I have a no spin condition on a front loading washer.  I have replaced the control board, door lock/switch, motor, motor control board,  and now after I run a diagnostics test it tells me to replace the speed control board.  Any help would be appreciated!
Wan
  • Replies 6
my information doesn't show 3 boards. I think the speed control board is the motor control board.
you may want to double check all the connnections.
speed board and motor controler are one and the same, look for broken wires near the plug on the speed board
grab tub and pull it towards the speed board to simulate an off balance load, watch where the tub is going to pinch the wires between the tub and board, one of those fine wires is squashed or broken
also a binding tub can give the speed board error, so try machine with belt off
I just came back from checking all the wiring and the connections.  Everything looked good, but it felt like the plug to the motor may not have been on all the way.  So, I ran another diagnostics test and it performs every step all the way through incuding the final spin.  This time at the end of the test I get a E47 (board thinks the door PTC circuit is open in spin)  It tells you to refer to test 9.  Test 9 says to remove the door lock assembly and measure the resistance of the PTC.  What is the PTC?  I measured the resistance accross all the terminals on the door lock assembly and everything is open.
What does PTC stand for?
Thanks for all your help!
Wan
PTC is part of the door lock
click on picture
PTC= Positive Temperature Coefficient
As always, you guy's are awesome!  Thank you for your help!
Wan
