always the farthest!!!!
grey shrek
I was wondering the other day , as I stepped off the elevator and started walking to the app. on the 3rd. floor that happened to be the farthest away, have I ever stepped out of the elevator and had a service call at the nearest app.  The answer is NO! What company does their service work and  why is it fair. Also that day , had 2 calls down 2 diff. deadend roads ---- yup--last house both times....is there no justice....Anyone else have this luck or care to gloat about always having the nearest..
WITH ME ITS THE HOUSE WITH NO NUMBER !  AND THERES NO NUMBER ON THE HOUSES ON EACH SIDE OF THE ONE I "THINK IT IS " ( thank god for cell phones)
for me its which way to turn when you get off the elevator, its a 50/50 chance
but unless there is a sign on the wall i will turn the wrong way EVERY time
