Samsung Ref RS2555Sl
megadan66
Gotta go look at this tommorow.Complaint is the fridge is hovering around 50F.If U could help me out with a repair manual please............Thanx Dan
here's one Samsung Technical Bulletin
I have (2) PDF manuals I could email to you.
Samsung Service Guide Model: RS24**  RS25**  RS26**  RS27**  22 MB
Samsung Service Guide Model: RS2533SW (also mentions RS2555) 6 MB
 I could send them both if your email box can hold the 25 MB one.
If U Could send me the Rs2553sw to megadan66@comcast.net .I went out on this thing and it has a defrost problem in the refrigerator(never thought I'd ever say that).At first I thought it was the heater cause when I checked it for continuity I got none until I turned my ohm meter to the highest setting.Now I had a repair manual for another SxS Samsung but could not get the diagnostic mode(which would tell me if the heater was bad)to run.Is that heater running on ac or dc ? I did check the thermal fuse and the sensor.What should those sensors read ?Also if anybody has the exact manual for this it would be greatly appreciated.
manuals sent
(1) 6 MB
(1) 11 MB part A
(1) 11 MB part B
