wiring schematic mod 278.4228890 kenmore
texasred
Does anyone have access for schematic for this oven? Its old and the one in the unit is gone. Thanks.
  • Replies 9
Seems to be a Roper, made by GE...
still looking...
what kind of problem are you having ?
Someone disconnected all wiring to the main control board trying to determine proper reconnect
I've run into this problem on occasion (needing the wiring diagram but it's been "disappeared" from the appliance). If I can't find the wiring diagram, I tell the customer that they will need to order a new diagram from the manufacturer or vendor-- in this case, Sears-- and to call you back after they get it. This saves you from having to sit on the phone, pressing "1" for English so you can wait half an hour to talk to a corporate bureaucrat. Typically, the cost is insignificant compared to the rest of the job and it's never been an issue. People understand that it's something you gotta have and, at least half the time, the customer was the one who removed it for "safe keeping" and lost it. The other half was some slime-ball parts changing monkey who "borrowed" it.
  • 3 weeks later...
customer has asked sears. they say no can find!! any other ideas on how to wire without schematic or some other place can find the schematic?
Is it this replacemnt kit that includes the the wires and the oven sensor (may not be needed) ?
click on picture
4342994 CNTRL-ELEC Part Instruction Sheet  attachment.php?id=2760
I have the board. Another repair company had removed the old board and did not label the wires. I need the schematic or some way to reconnect the wiring. The schematic that was in the oven has been remove.
The Instruction Sheet above, lists the wire colors.
Duh!:bathead: I will try and report back. Thanks for info
Thanks for info job completed and billed! On to the memorial weekend!:woot:
