Kenmore Dryer Model # 110.66812690
jambatt
Need a wiring diagram for this puppy. Got some connectors that crispy crittered and need to see if there is a way to bypass some of them. How  bout' it Reg? You the man when it comes to trackin' down these hard to find diagrams.:rocker:
  • Replies 10
Thanks Reg, but this model has a small circuit board in the mix. Not sure, but I think it might have something to do with Auto Dry. Appreciate the effort though. Crispy crittered one terminal on the connector that holds the board. Wiring harness no longer available according to several sites. Would have been way too expensive anyway. Just trying to figure out a way to salvage the damn thing for the owner.
here's a model, but your's doesn't have the Guard Switch
and it shows the physical pin-out of the board at the bottom of the page.
LEQ9558KT1 Wiring Sheet
Laundry Products L-63 Whirlpool 27" Gas & Electric Dryers
RepairClinic has the wiring harness but out of stock (7-10 days) $133
but they do have the connector, but it may not have any pins in it ?
click on picture
Thanks again Reg. I think this is the one I'm lookin' for. Have the connector, but the pins are not in it. That's part of the problem. Can salvage four of the five pins. trying to re-engineer the fifth pin to accept the circuit board. Then have to find the original cause of the overload that crispy crittered it.
what color wire is bad ?
Orange/white
[user=24427]jambatt[/user] wrote:
Orange/white
black/black :D
Orange/white is the main power into the board that keeps the Timer motor off until the sensor determines the clothes are dry, then the Timer runs and the Timer turns the heat off for the last 10 minutes.
Gotcha.... ain't going to be able to bypass it then I don't guess. Tryin' to get up enough nerve to try to solder the wire to whats left of the pin. This is gonna' be tricky but maybe I can do it without burning up the rest of the pin. Not much left to work with. Appreciate the help.
Only used in the Auto-Dry Cycles, not used in the Timed Dry Cycles
May have to run it on Timed Dry if I can't get the pin fixed.
