This unit is freezing the veggies and beer:yikes:. I am going out on unit today. Their have been about 8 techs that have looked at the beer bomb!! unit has a thermodisc in fridge side. Long drive to residence. Airflow could be culprit?  Any ideas much appreciated!! or for an enjoyable drive in the 103 degree heat you are welcome to ride along!!:cheers:
I have a Service Bulletin for REFRIGERATORS BUILT-IN SIDE-BY-SIDE MODELS FRESH FOOD TOO COLD REF 18-03
Damper Door problems...
Monogram  Side-by-Side Models: ZIS360NM, ZISB360DM,ZISW360DM, ZISS360DM/NM, ZIS420NM, ZISB420DM,ZISW420DM, ZISS420DM/NM, ZIS480NM, ZISB480DM,ZISW480DM, ZISS480DM/NM.
but i just checked and it uses a different Damper Door
  • 7 years later...
I can't find this service bulletin anywhere. Can you email it to me please?
thermodisc is for lights in case lights remain on - will cut them out
Any parts been changed on it
Make sure that condensor is clean! it is wedged into the rear compartment and is smaller than usual, this will make it sensitive to poor air circulation- a slow cond. fan motor can cause similar problems...
Check damper and air flow anyway(?)
Why are you guys posting on a topic from 2008?? Bro Wayne,  you are looking for the bulletin,  now others are confusing you with the OP and questions from 2008.. It's best to start your own thread. .Guys please read threads carefully otherwise lots of confusion.
Edited by DurhamAppliance
  • Like 2
Dang, didn't even notice that, thanks!
