GE Washer WCSR4170G1WW
jambatt
Client says first load worked fine. Next load machine agitated and  drained but would not spin. Machine will fill and drain but now it won't agitate and spin. GE eleminated the tranny but created new problems. There is a inline fuse hiding somewhere in the harness and lid switch supposedly can't be jumped out. Anyone run into this problem before or got any ideas???
  • Replies 4
This have the inverrter board on the motor??  if so the fuse is in the harness down to the motor/board. If not inverter ignore this .....;)
Thanks for the reply Pegi. Yes, this is the latest and greatest from the geniuses at GE.
Thanks Reg. Still not sure what the problem is. Tech sheet is almost worthless. Does have wiring diagram though. Goin' back today and really tear into it.
