GE Monogram Icemaker ZDIS15CSSH
jambatt
Unit will not go into harvest cycle. Evaporator freezes fine but will not cut off and release ice block onto wire cutters. Suspect ice control thermistor but cannot find tech sheet or wiring diagram. Anyone run into this problem before? Any way to troubleshoot control board? Contol board seems awfully expensive.
Howdy, Jambatt. There's an update out on this unit, which includes a different procedure for entering diagnostic mode. It's attached. See if that hepsya.
REF03-01.pdf
Thanks O Fermented One. Did you get the new flow chart?
I did, indeed. Domo! I'm saving it 'cuz I'm gonna make a good post out of it at my website. :silly:
