Service Matters job aids
OAR
Do I need to have some sort of subscription to Service Matters to download tech info published after 2005? I would be happy to pay...What a tresure!
Specificaly looking for tech info on the cabrio washer line...either tech sheet is well hidden or has been lifted...oh, by the way...prob dosn't matter but this machine has a kenmore elite tag on it.
  • Replies 8
No, you do not.
Are you having trouble downloading it?
It's up now..not sure what was going on
I just tried downloading it.
I have a cable internet connection and it was still a little slow to download, but it worked for me.
Are you on dial up or something faster?
How did you find the Cabrio tech sheet If you only have a Kenmore model number ??
I haven't been able to do that.  Where did you search exactly, and what did you put in the search box?
Thanks for any help
Mike
IF you have a Kenmore product...AND it was manufactured by Whirlpool, you know this because of the prefix like 110. or 665.  etc, take the model number less the prefix of 110. or 665. etc and put in into the tech sheet/wiring diagrams search box in Service Matters, will be a 50/50 % chance it will bring up something, is worth a try...then if it does bring up a tech sheet or wiring sheet check to see if it looks right as sometimes it will bring up a dryer when you put in the model number of say a refrigerator....happens sometimes if the same model number is used with the different sorce prefix...
http://servicematters.com/docs/doc_main.htm
Well 50/50% is a whole lot better than zero! Thanks Pegi :)
