Viking Range Repair Manual
shmonkey
Can anyone please provide a manual for this model?  I never like to open up appliances without a roadmap of what to remove first to access the wires I need to test.
I need to do a current reading on my oven ignitor and I'm not sure of the best place to insert the meter.  I do not have a clamp-on amp meter, only a probe-type multi-meter.
Thanks.
I may be getting a manual for that in a few days...
depending on how often you need/use these items...
(you get what you pay for)
Sometimes on sale or coupons (take on-line flyer ad to store)
(may need a few)
click on picture $ 3.99
click on picture $ 4.99
click on picture $ 11.99
click on picture $ 16.99
click on picture $ 39.99
click on picture $ 49.99
click on picture $ 79.99
from user manual:
7 sensitivity levels
Mechanical air pumping
Real time adjustment / response
concentrations as small as 3 Gr. per Yr.
click on picture $1.99
click on picture $ 9.99
Four precision lenses provide just the right magnification for the job
Brilliant long-lasting LED worklight
Adjustable head strap with antiglare visor
15% coupon till 9/03 reg & sale prices
The Oven Ignitor is in series with the Gas Safety Valve, which won't open until the Ignitor reaches a certain temperature at which time the Ignitor amperage reaches about 3.0 amps, and the Gas Safety Valve (which = 1 OHM) reahces 3.0 amps which is 3.0 volts at the Gas Valve.
Because the Gas Valve = 1 OHM, Volts = Amps at the Gas Valve.
if anyone has a copy of the manual (since Xdrive is caput) that was the actual subject of this thread, though I do appreciate the input regarding volts and amps.
I will also use the furnished links to procure a clamp on!
