How Do you replace the fuel filter on a oil burner
nmykytyn
OK so it's still warm enough in the Hudson Valley, trees not yet turning so I want to be ahead of the curve. What is the procedure for changing the fuel filter (not the air filter I know how to do that) on an oil furnace.
  • Replies 1
Fuel filter should be located on the section of tubing coming out of the tank. Shut off the fuel from the tank-- there should be a hand shutoff between the tank and filter canister. The unscrew the filter housing and replace the filter. Housing will either screw off or is held in place with a single bolt on top. All that's the easy part. Then you graduate to the still-easy-but-more-involved part: purging air from the fuel line. See this page for details.
