Thermador Model # CM301UW
Waneewek
I have a in wall Thermador Oven/ convection oven/ microwave and when I try to use the microwave I blow the 20 amp fuse located inside of the unit.  Do you have any technical data on this unit?
Wan
I couldn't find anything on
CM301UW
but maybe
CM301W Bosch / Thermador
parts diagrams at Sears, but no wiring diagram, yet.
It could be the Door interlock safety switch system... as on many other MW's
Thanks regUS.  I was hoping to get some info on this before pulling it out of the wall.  I will check out those switches.
Thanks again,
Wan
