Maytag #MAV7550AWW
jambatt
Washer does not completely drain in spin cycle. Is this a two speed motor? Does motor reverse for drain cycle?  Spin cycle seems a little slow compared to other machines.  Also need tech sheet and wiring diagram.
Thanks Reg. Suspect timer problem on final rinse cycle. Fills , agitates,  times out, and shuts off without draining or spinning.
