Rheem RGPH-07EAUER... igntor won't glow
jbarch
I have a gas furnace, Rheeem model RGPH-07EAUER. I replaced the HSI (ignitor) almost a year ago, but now it is acting up again. The HSI doesn't glow, and consequently we get no ignition/no heat.
Trying to measure the voltage, but I'm unsure about where to measure it. First thought was to unplug the HSI connection, and measure there on the incoming wires (see photo). Doing this I get zero voltage when I call for heat. Or should I reconnect and just place the probes directly on the gritty HSI surface?
FWIW, here's the sequence of what happens when I call for heat:
1. Furnace does the usual 30 sec. warm up.
2. Gas valve opens up but HSI is not glowing, so no ignition.
3. Blower fan comes on as normal, but of course blows only cool air. Seems odd that this step happens without ignition.
4. Faint smell of gas after I shut it off, because of course it never got a chance to combust.
Thanks in advance for any help,
JB
  • Replies 11
I'm not an HVAC expert, but there should be voltage there...
or when connected, if your probes (or smaller wires) will fit into the back side of the plug.
You could also measure the OHMS of the Glow Ignitor. (good or OPEN reading)
I just tried to fire it up again with the HSI connected.
Using my little "circuit alert" tester (not the multimeter) I get an indication that there's voltage coming in from the furnace. But there's no voltage in the two white wires for the HSI, seen in the second photo above.
  • 2 weeks later...
That ignitor is bad, can't you see the white spot?
Naw, the ignitor is fine... I should've posted earier to say that I had to replace the circuit board.
cheers
Otay :D
I'm with the applianceman here, if that ignitor is working, it does not look like it will work for very long.  I'd replace it.
  • 3 weeks later...
My brother now has the same problem, same Furnace... intermittent Glow...
anyone have a Parts List & Service Manual for the RPGH-07EAUER ?
I cant speak for Rheem; however, Trane hot surface ignitors have to register between 55 and 75 ohms or else you will experience intermittent problems.
Measure your ohms and calculate your current based on the voltage applied (E=IR) and if you get less than 1 amp, you may have to replace it.
The carbide material experiences a resistance INCREASE in the material with age and the higher resistance causes less current and thus intermittent failures to ignite.  Another potential issue is with fissure cracks.  An otherwise good ignitor exhibiting continuity through it in a cold state will expand and cause the fissure crack to open and break the circuit - that problem will drive you nuts.
Hope that helps.
  • 4 weeks later...
ebusinessbuilder
Great suggestions ...
BTW: My Rheem RGPH 12EARJR was installed in Feb 1998 and I have the owner's manual which on page 42 states Check for 60-90VAC at Igniter, terminals and at (IFC) terminals -> IF YES, REPLACE IGNITER
Did you replace that worn out ignitor yet? you know, the one with the white spot.
