Older Carrier HVAC Unit
papollonia
Hello;
I posted a question about this unit about two weeks.
Someone replied with the problem should be the run Cap.
Then that night the forum had some issues, my username and post was wiped out.
I replaced the run Cap. today.
I then turned on the power, made sure the gas line was on, then turned the t-stat to around 80 degress, the unit went on, but the gas is not lighting.
I had this issue with the one upstairs unit, but i can remember what was done.
Here is a picture of the inside of the unit... If that helps..
Thanks in advance
Paul
  • Replies 1
I noticed a wire was disconnected.
I re-connected it and now the heater fires up!!!!
But I still have no fan blower, and when i leave the unit on for a little while, a funkie smell comes up from the vents.
I turned everything off at the circuit breaker..
Does anyone know how I can troubleshoot the fan issue???
Thanks again
