Kenmore SxS Model 106.56544400
Waneewek
How does the front escutcheon plate over the door dispenser come off.  I thought that they all pulled off but this one feels like it's going to snap.  I need to get at the ice dispenser switch to see if it's bad, or the auger motor that's bad.
Can I get the wiring diagram/technical data for this too?
Wan
  • Replies 5
Just need to work it carefully using putty knife. If it cracks-- and it may-- ain't no thang, it's not an expensive part.
[user=13125]Waneewek[/user] wrote:
How does the front escutcheon plate over the door dispenser come off.  I thought that they all pulled off but this one feels like it's going to snap...
maybe a little heat from a hair dryer ?
SearsPartsDirect says this is the Service & Wiring Sheet
https://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%202261147.pdf
Not sure if it is the same , but :  there could be two little slots on the very bottom , insert screw driver and pop out and then the plate slides up a bit and off.
Thank you all for your help!
Good tips on fine points of technique, Reg and Shrek. :dude:
