kitchenaid dishwasher KUDM25SHWH1
cuzzin sam
Not that I want to sniff glue mind you, but today I replaced the door seal and the lower "bottom of the door" seal. I thought I put the new lower seal on just like I peeled the old one off but, I put it on, it falls off, I put it on, it falls off... Does this need to be glued on or could I possibly (gasp) but putting it on wrong? Hmmmm. Thanks in advance for all the help. Cuz
  • Replies 5
from another Whirlpool Dishwasher MDB6600AW
[align=left]Door Gasket Replacement[/align]
[align=left]1. To ease installation, wet gasket with water.[/align]
[align=left]2. Starting in the lower right corner, Gently work gasket into the recess of Tub up the right side.[/align]
[align=left]3. With other end, place gasket flush with the Tub in lower left corner.[/align]
[align=left]4. Gently work gasket in to the recess of the Tub, up the left side, and across the top.[/align]
  Thanks Reg for replying but I'm talking about the one that goes onto the bottom of the door itself, not the one on the tub body.
  Just looked it up again and its called the lower door seal, but unfortunately it must be child proof
hhmmm... from RepairClinic:
Dishwasher lower door seal kit
*Also order this to adhere seal to door panel: 1065754
(Manufacturer part number 4172127 is RepairClinic item number 3123.)
"White silicone adhesive, specially formulated for use in the dishwasher to adhere tine tips & door gaskets"
  Ah-hah. Adhere sounds like glue is in my future. Thanks Reg, you've been a huge help as usual . Cuzzin Sam
