condenser fan motor
denrayr
a friends heat pump needs a new condenser fan motor and the number i got off the old one is AO SMITH - F48SJ8L5 it seems to sub to a generic one on line. the problem is the original motor has tabs welded to the body for mounting and the replacement is missing these tabs. is there a mounting kit i can get to add the tabs to the generic motor? i will be checking with the local supply house on monday but thought i might try here as well.
  • Replies 5
AO Smith kit part # 615157
you're the man. how did you find that info?
OK, Googled F48SJ8L5 (no Yahoo search finds)
found:
http://www.aqua-man.com/TechTips/motorManDetails.asp?mfg_number=F48SJ8L5&motorID=5688
above Motor picture, near Get Pricing Info,
[align=center]Notes
(shown below)[/align]        3
[align=center]3 Original Lug Mounted-Use with Kit #615157[/align]
[align=center] [/align]
[align=center]Google Search: smith 615157 kit[/align]
[align=center]a few results down = [PDF] Dimensions File Format: PDF/Adobe Acrobat -
615157. For adapting 5-1/2" standard motors .... These kits are only suitable to be used on A.O. Smith motors manufactured in Hungary. ... http://www.cshincorporated.com/pdf/AO241thru260.pdf[/align]
 page 249 (PDF page 9 of 20)
thanks for posting how you found it. i dont have a knack for finding things like that so i had to ask, maybe one day i will develop the skill. i have a friend that can find anything on google, he just always knows what to type to get an accurate, precise search. its a gift i think....
Various mounts:
A60055__18.95
KIT 200__14.07
A67804K_15.85
TFM-55__18.95
A67805K_13.27
A60007K_12.90
I don't know the prices now but google or put the part numbers into HVAC sites for specs. These are the most popular.
