Older Carrier HVAC
papollonia
Hey guys:
I love this forum.
It has saved me ton of money..
and I love to work on stuff and learn..
Well I have older carrier unit,, 1993ish.
I posted a few months and was given help on replacing the start cap, which I did and the unit has worked great.
The current problem is a humming noise.
The fan blower goes on the unit never fires up.
I took the cover off and used a tube and one of the relay boxes is humming, it sounds like it is trying to connect but can not..
I took a picture and labeled which one was making noise..
Is this hard to replace?
Do I need to replace it?
Were does the common man, non HVAC tech get parts?
Thanks so much..
Paul
  • Replies 4
Check the low voltage to the coil. These will usually come from the transformer. 24V. is what you need
Thank you so much for replng..
I have a real Novice question:
What color would that wire be that I need to test?
Where is the coil / Transformer?
Is it right in front of my eyes and I am not seeing it!!!  :)
Thanks..
dont do anything if you are just hearing a noise . this is the reversing valve relay . it might make a noise as it gets older , this is normal .  are you getting cold air when you should be getting heat ? if i understand your post somethings not turning on ?  the relays shown have nothing to do with something not turning on , only if the system will blow heat or ac WHEN TURNED ON AND RUNNING
Thanks for replying...
' are you getting cold air when you should be getting heat ? if i understand your post somethings not turning on ? '
Yes getting Cold air when heat should be on...
Any ideas what it could be?
The only noise i hear is from that relay I pointed to in my picture... It just humms, maybe sounds more like clicking...
What can I do to help us figure this out???
