York E2FD036S06A Heat Pump
mfeirman
I have an old York heat pump unit whichh is killing my electricity bills. Trying to get more info on the unit I have (tonnage, seers, etc) or maybe a user manual. Any info on this York model (E2FD036S06A) would be greatly appreciated.
Mark
  • Replies 6
Three ton unit. What information do you need ?
What's your outdoor temperature & your location
Is the Compressor running ?
Is it 8 SEER?
I am located on Long Island (New York) and the compressor does not run under 30 degrees, so basically I have been running on 100% electric for the past 2 months. Killing my bills.
Trying tot undertsand approximately how much I would save to go up to a 14 SEER unit or 16 SEER. And then understand if it pays to go to 16 SEER vs the 14 SEER.
Did you ever get in touch with Louis ?
The increase in SEER won't help much at those low temperatures if the Compressor doesn't run...
Is gas available (NG, Propane, etc) (cheaper than electric, in your area) ?
Heat pumps are crap when the temps are below 30ish degrees.
