Water Heater With Radiant Loop/Heat Exchanger
etherhuffer
Any of you ever used a hot water tank with a heat exchanger for radiant heat? I see that several companies, AO Smith being one, that have extra ports, either for a heat exchanger or for direct flow(code being the issue). A gas water heater is not high technology, but durability would be nice to know. And ease of install. Free association thoughts allowed and encouraged.
  • Replies 4
I'm not an HVAC expert, but the (gas) Lennox Complete Heat System that we had installed a few years ago
could be used for Radiant Baseboard Heaters.
Right now it's used as home heating.
The (Direct Vent) Water Heater heats the water that is used by the Air Handler (in place of Furnace),
and is the same water that is used for domestic hot water.
I had thought of using it warm the basement floor with under-floor copper tubing.
I have heard pro's and con's about the combo furnace water units. Expense?
yes & no, maybe...
We had a nearly 20yr old traditional Furnace and Water Heater in the middle of the small (20x25) basement of our Tri-Level
with the the chimney for exahust.
The Water Heater needed replacement and the Furnace didn't look very good.
We wanted to get a traditional Direct Vent Furnace and Water Heater and have them installed near a wall of the basement.
One company wanted nearly $5000 installed and said the Supply & Return Ducting would be a problem.
Then I found the CompleteHeat installed for $3200.
No problem with the Ducting, just installed the system about 10 feet from original, right under the existing supply and return ducts.
I don't know how much of that was installation cost, but yes, the units do seem a little expensive.
Now there's only one "flame" and it's a direct vent, no cold outside air has to "seep" into the house to replace the air that is lost up the chimney from the water heater and furnace.
I like the idea Reg, just not the brand name.
