Trane XE80 blower noise
Kurt01
I have a Trane XE80, model #TUD080C924H1, serial #K351TLJ1G - I think it might be a 1995.
The furnace seems to run just fine except for some noise when the blower kicks in.   The noise does stop after a few minutes and although there is still some noise after that, its not the loud noise which seems to say a problem is developing.
I pulled the lower panel off and the blower fins seem to spin quite easily.   They are dirty though as is the whole bottom section.  Not terriably terriably dirty, but dirty yet the same.
I bought the house last year and my guess is that the furnace motor had never been oiled.   From looking in the lower area of the furnace it appears that a panel with a bunch of wires would need to be removed, the blower assembly unbolted thus allowing it to slide out.
Guess what I don't know is if I'm on the right track or not.   Is the above how I need to get at the blower motor?   And if so, once I get it out, then what?   Does it seem that the noise is most likely fixable via oiling the motor?   What kind of oil?   Can anyone point me towards any drawings, preventative maint tips, etc?
Thank you so much for the help!
Read my article Gas Heat Maintenance on this forum. :D
Bobice - very nice writeup.   I have printed it and plan on following it to the 't' over the weekend.   Thank you for the instruction.
Now, if I may be so bold but to ask a couple more questions......
1) I believe the year of my Trane XE80 is a '95.   Since it is a bit old, I'm assuming that it most likely has the oil ports.   Is this a correct assumption?
2) I'm not sure I know what electric motor oil is.   Is that the lubricating spray in the can that you can get at Menards in the electrical section that is meant for electrical contacts, etc.?   I'm guessing its not 3-in-1 household oil nor automative oil.
3) Is there some kind of guide line as to how long a furnace should last?   For example, seems like the rule of thumb for a gas water heater is 10-12 years.   Anything for gas furnaces?
Thanks again for all the help!
3 n 1 motor oil, comes in a blue and white can. Been using it for years. :)
