JENN-AIR M#JGS8850ADQ strange error code?..
Rocket Appliance
Any ideas? I thought maybe bad touch pad?..Ive powered down the range for 5mins  the code went away...for 12 hours then came back??....I returned did the same thing again and the code DID NOT come back..... I set the oven to 350 and it came up to temp just fine....cycled just fine, no code all well.......Im expecting a call back...I wont charge the customer until I find the problem....;)
Thanks all!
  Jolee.
  • Replies 4
"F1-8 Shorted key (pad) in membrane switch.
Ensure ribbon cable is securely connected, inspect ribbon cable and connector (shorts, breakage, corrosion, etc.).
If OK, replace control."
JGS8850ADQ Tech Sheet
sounds like it could be a bad keypad (gookus in the switches causing "leakage", or a "near short" at times)
but at $ 268 ?
click on picture
you need 74005741  Bisque
Thanks RegUS,...Your saying that it may be the keypad (membrane) that may be shorted or corroded...when they say replace control do they mean the keypad or the EOC?...or is it all one on this unit?...
Also,..... you rock!:).....and yes you were right "bisque"...lol..
Thanks RegUS!
I don't know if they mean the keypad
or the (EOC  $ 180) 74006387 OR 74007217
With the Tech Sheet, you could test each of the Key Pads with an Ohm Meter .......
will do!.....thanks RegUS
