Frigidaire RAC
clman_old
Frigidaire RAC
M#: FAC084N7A
PC Board#: 5304436531
Does anyony have a good used one ?
Does anyone know if a 5304436532 will work ?
  • Replies 4
It looks like it may be the same, except the 5304436532 has the 2-pin connector for the optional Ionizer.
Is the Controller bad ?
Yes. No secondary voltage from the trans. I noticed an added relay on the "2" board says filter. Saw a photo on E-Bay. I didn't see the ionizer plug.
The schematic is exactly the same on the "1" & "2" boards. The added relay on the "2" obvoiusly outputs to one of the existing terminals. I guess if the IC software is the same it will sub. Might take a shot.
