anyone have a manual for this range,thanks so much.
  • Replies 10
  • RegUS_PatOff
    4
  • grey shrek
CPLES399ECA ?
very well could be. the # i gave you is the one the costomer gave me over the phone. please send me the manual for the # you are showing. i'm in canada so mabey the #"s are different. thanks.i' going to work on the range this afternoon.
hi regus. i looked at the range tonight. model # for sure is cplef398aca.  their is no thech sheet or wireing diagram with it. the one you sent doesn't match. but thanks for it anyway. my findings were: both bake and broil elements are good. 240v to control board for oven. one leg that feeds the bake element from control board is showing 120v. the other leg comming from control board and feeds one side of each of bake and broil elements shows 0v.i believe their must be a bad relay on the board  for that leg. no error codes. all display lights work for ,bake ,broil ,etc and the clock works.what do ya think? on the way  home i realized i didn't check for oven sensor.thanks for your reply.
I found it at WWW.frigidaire.com/manuals.aspx   Shows owners  ,wiring , parts manuals. Hope this helps. I have no comp. skills so this is the best I can do.  Canada - where?
thanks.. i'm from st thomas ontario.and you?. i regret to say the manual siteyou sent here won't come up. thanks  again.  john.
links work for me.. do you get an error message ?
Try right_click on the link and " Save Target As... "
Milwaukee...
The long way is :  WWW.frigidaire.com   then then go to customer support  then go to guides/manuals.
thanks gray one and reg for all your help.
