Frigidaire front loader Model FWTR64RH
KarlK
Washer will not spin or empty. I have read some of the discussions concerning the Frigidaire washer and have already disconnected the drain hose and removed the two quarters I found therein. I reconnected and while it will fill with water it will only agitate and will cycle through and shut off. I feel that there is power to to the motor as I hear noise and feel a vibration in the motor but no drainage. Is the motor shot, or any other suggestions?
  • Replies 7
FWTR64RH   :ooo:
maybe
FWTR645RHS1
OR
FWTR645RHS0
Does it Spin, but the Pump Motor doesn't work ?
or does it Agitate during the Spin Cycle ?
[align=left] Probably something still in that pump.  If you can feel the pump humming, then it's jammed.  Wrote a haiku about this just for you:
[/align][align=center]3466634977_7bb2c252a1_t.jpg
[/align][align=center]Front-Loading washer,
drain pump hummms but will not drain.
Gookus stuck in pump. [/align]
[align=center]bambooleaficon.gif[/align]
[align=left]
[/align]
Thank you for the quick reply.
I mistakenly took the model number from the Energyguide but the model number is FSE748GFS1 . The motor is much smaller. I have thought of taking it out to check the insides.
I took out the pump and found a large piece of plastic in the motor.
The raised spines on the pump are intact but the backing for the spine is chipped out in a few spots. Will this still work or should I replace the motor?
Another success story for the Samuari as my washer is up and running.
BOOJAH!
