Replacing a GE Oven Control on Mod #JBP65GV3WH replacment part #JBP65GV3Wh
Wingnuts45
Looking for a wiring diagram for the new replacement board....Thanks
  • Replies 1
  • Wingnuts45
Wingnuts45
The original board has Broil (blue wire), Bake (yellow wire), N (white wire) & Line (red wire).
The new board has one board mounted spade connector for AC N ( white wire), and the other coonetions are on 2 relays. Relay 1 has 3 spade connectors labeled COM, NO & NC. Relay 2 has 2 spade connectors labeled COM & NO.
Relay 1 purple dot...relay 2 has a yellow dot
