Delonghi DH40P Dihumidifier
aokappliance
Compressor won't run. Pause Light is on.
  • Replies 7
Are you getting voltage to the compressor? If so, then the compressor is shot. If not, then you gotta trace it back till you find it. Do you have the wiring diagram?
Don't have wiring diagram. I'm thinking the problem might be with pause light on that sensor thinks the ambiant temp. is too cold to run the compressor. I'm not sure if that sensor is part of the board or what. Could use the service manual.
Which Light ?
The Light on the far right is marked, F-  (ferinhieght-) Pause.
not mentioned in the Product Manual
but it would seem like it thinks the room temperature is too cold
Could use the service manual. Can't identify location of sensor. Couldn't find it in Parts breakdown.
It may be some type of "ice" switch.
do you have a link to the parts manual or upload it here ?  200k MAX
