Click here to take the quiz.
GE wall oven
fixit guy
Model # JTP15WOW2WW  This unit displays f-2 code.  The oven senor ohms at 1100 and at 350 degrees around 1650 ohms.  From ground to sensor is around 12000m.  Will this effect the oven or this little bit enough to make a difference?
Fixit guy........
from a similar manual:
F2
Oven Over Temperature Exceeded 590F with door in unlocked position or 990F with door locked
Remember:
ERG measures resistance of sensor circuit, not actual oven temp. During Clean Operation
If actual over temperature condition did occurred:
Look for welded relay contacts.
If over temperature condition did not occur:
Look for a high resistance connection or any other cause of high resistance in the sensor circuit.
Open thermal switch (self - resetting) located on floor of component compartment. Switch is normally closed and will open if area overheats due to inoperative cooling fan.
Check Fan Operation.
There should be NO continuity between either sensor lead and ground
Thanks for the replies.  I made an error in my post, it was a F-3 and sometimes F-4 code.  I replaced the sensor and cut the plug out of it and so far no problems.  I will let you know if the problem comes back.
Fixit Guy
