hanging furnace: Reznor xl 170: need help with wiring
jm56
Just got a hanging fan for my workshop: Reznor xl 170, current model number is f-165
I have read the manual available at rezspce.com. This is for the newest mondle with spark pilot.
I have an older version with gas pilot.
It also has a basic gas valve, only two wire connections: "ITT General Controls."
A wiring box is attached to the back of the fan motor housing, with a transformer attached to one end of the box.
Wires and connection:
 black  yellow  red  ::: attached to 2 sensors in the furnace, black connected to both
 Tan    white        ::: motor
 black  white        ::: transformer
 screws  2           ::: transformer
 screws  2           ::: gas valve
This is how I figger it should be wired:
The 2 transformer screws, through a thermostat (in series , one side), to the gas valve's 2 screws
AC
  black  :: connect to:  black to the sensors
  white  :: connect to:  white motor   and white transformer
sensors (I am assuming the larger black sensor is the fan control switch)
  black  (hot)                  :: connect to:   AC black
  yellow (sensor: heat limit)   :: connect to:  white transformer
  red    (sensor: fan control)  :: connect to:  tan  motor
Am I correct?
Jesse
  • Replies 1
show us a picture
