    • 25 May 2024 02:00 PM Until 03:00 PM
      This week, we'll be workshopping some troubleshooting case studies taken from the forums right here at Appliantology. Come ready to walk through some real on-the-job examples, figure why the troubleshoot went the way it did, and think about what could have been done better.
      When: Saturday, May 25 @10:00 AM Eastern Time.
Lower Drawer on Fisher Paykel DD602
RVChaser
I recently removed the lower drawer on my Dishwasher to soak up water from a leak but now have a problem. When you open the lower drawer it "chirps" like normal but the LCD Handle display won't light along with the LED in the jet dry reservoir. I replaced the LED handle and the control board but still have the same result (I exchanged these parts with the top drawer and the top is still working fine). Any ideas?
  • Replies 4
  • RVChaser
Posted Images
By LED handle, do mean the LED display badge?
Which control board did you replace? The big (expensive) one?
The LCD display is what I meant, that doesn't light up at all. If I move it to the top drawer it lights up and works fine. Yes, I replaced the large control board (behind the front cover - white about 10"X 5" that has the various components plugged into it)
If I remember something about the F&P Controller gets it's power through the Drain Pump.
Check and compare  Drain Pump resistances.
That's for the FP washing machine. The badge on the dishdrawer is supplied by the control board.
RV, only thing left is the wiring harness that connects the badge to the control board. Swap that out with the upper drawer, too.
