I need either a service manual or tech sheet for a Kenmore/Whirlpool ice machine, model 106.89482997, serial number ES4718403. I think that makes it a 2007 model, Right?
This model has the electronic control system and a switch pad with 5 button/pads. They are left to right On, Off, Clean Cycle, Twice Ice, Norm Ice. I downloaded the owners manual but it is not much help. The Kenmore technical lit is so hard to find. Thank you for any assistance you can provide.
Jerry Duff
36 years techin' and still tickin'.nm
  • Replies 6
  • RegUS_PatOff
  • jtduffer
  • Vance R
  • Mike S.
Hey thanks this is good but lacking the procedure to initiate the self diagnostic procedure. The correct sequence of buttons to start the diagnostic program. Also doesn't have the traditional diagnostic blocks of what to check when certain conditions arise. Hopefully that is in the manual.
So if you could please pass along the service manual for this model as well it would be put to good use. Again model number is 106.89482997, serial number ES4718403.
Thank you so much
Jerry Duff
link PM'd  60 MB
  • 12 years later...
Did anybodyever  find the manual ?.... I am in need
Uploaded pending approval:
Thanks, Vance! Approved.
