Have this whirlpool dishwasher,it's just over 1 year old.The dispenser door won't open everything else works great.What could be wrong?
  • Replies 9
  • RegUS_PatOff
    5
  • llky
could be a bad Dispenser (280 to 340 OHMS)
or a bad (Triac on the) Controller
DU1055XTSQ2 Tech Sheets
I removed the front panel and checked the little dispenser motor and it ohms about 270 or so.Must be in the control board?
the Dispenser may just be a bimetal latch triggered by a resistor heater.
You may be able to supply 120v (and wait) to check it ...
This is a great way to check wax motors. I carry a test cord in my tool bag for this.
hhmm.. test cord .. OK
but what's with the Red & Black clips ?
is Black hot ? as in AC volts ?
or maybe it's just a 2-wire non-polarized plug ...
It's not a good picture, but there's an AC 120vac plug underneath the cord bundle. The alligator clips clip onto the spades of the wax motor. Wax motor isn't polarity sensitive so it doesn't matter which clip goes on what spade. Clip, plug, play!
hhmmm this same part number from the Accesories, Test Equipment web page
Black & White Wires are visible ...
Black is hot
Red is Neutral
Black is hot
Red is Neutral
Not sure what your point is. In using this cord with a wax motor, it doesn't matter which clip you put to which spade.
In some applications, it may be good to know that the red clip is on the neutral wire; but for testing a wax motor, machts nicht.
[user=1]Samurai Appliance Repair Man[/user] wrote:
.. In some applications, it may be good to know that the red clip is on the neutral wire ..
You may want to test a device / or connect the hot lead to a device that should already have (hot) power
and the rest of the machine is still powered ...
