Thanks in advance.
Do you have anything on the Sears/Gibson Top Freezer Fridge? Mfctr date 08/2004.
Sears # 253.7487440
  • RegUS_PatOff
  • red chili
Thanks for the links !
Do you have any way to take a sears # and find out what the Gibson model # is?
Unfortunately both the Parts list and Wiring Diag are the same document when downloaded - they're both the Wiring Diag. Not a problem, i think, yet. Haven't seen the beasty and it'll be easy enough to look up with the Sears # on your RepairClinic site if i do need a part. Sounds like the drain is frozen or it's a bad water valve.
Thanks again...
fixed parts link
