Bosch Downdraft exhaust unit DHD361UC
jambatt
Need service manual and any info about unit. Unit will not raise and lower. Any help would be appreciated.
  • Replies 7
Haven't seen any Bosch units, but a few other mfr's - all I have seen have some sort of filter proving switches between the up/down switch and the retracting motor, they are usually some flimsy microswitches with a springloaded actuator located in the face of the fan. When these fail in the down position, one must go to the motorbox located under the cupboards, disconnect the motor drive and manually wind it up using a socket drive etc, once it is in the up position, you will be able to locate the switches, if there are no filters, there is no action
I have a manual w/wiring diagrams for:
DOWNDRAFTS
DHD 805 AUC
DHD 865 AUC
DHD 905 AUC
DHD 965 AUC
DHG 565 AUC
Hey Reg, need manual for the DHD965AUC. PM to jambatt5@aol.com. Thanks for the info kdog. This unit doesn't seem to have a way to manually raise the filters.
βởşčĥ щΐяîйģ ₫їẵğяǻмš ặяз ήỗŧởѓỉọữşŁỷ ςяўÞťĩç.
link PM'd
Thanks Reg. Looks like I gotta' take the unit completely out of counter to get into it.
Usually you can remove some drawers from the counter to get at the lower mechanism, or clear out a few cupboards - the mechanisms and the fan are mounted down below
Thanks again kdog. This unit has to be completely removed to access the lower circuit board. Cook top was easy to remove. Much better access with it removed. Exhaust fan can be seperated from vent unit without disconnecting exhaust hose and the rest of the unit can be lifted out of the counter for much easier access.
