Requesting a service manual for this, sorry excuse of a washer! model# WWSE5240G0WW Thanks
  • Replies 10
  • tech1911
    5
  • RegUS_PatOff
    4
  • appl.tech.29501
31-9040 service manual may be similar
link PM'd
The model I am working on has a inverter board on the motor. I dont think that manual will be accurate to help diagnose this washer. If you have a manual that has the inverter board on the motor, I would appreciate it. Thanks for your help
I do still need the manual if you can find it. I have the inverter board status light codes, but I do not believe the motor is bad (2 blinks), and the belt is not slipping.
I think I have your cure but notes are at my house, I will post back when I get home
maybe this one 31-9145
link PM'd
[align=left]Profile Washers With Electronic Control and Mode Shifter Assembly[/align]
WPRE6100
WPRE8100
2 flashes means that the tub hub nut is loose. Tighten nut and to clear fault disconnect power to washer for 15 seconds, reconnect power and open and shut the lid 5 times within 30 seconds
Thanks. I had already replaced the hub nut, old one threads were stripped and tub loose. Then it would fill and drain only. I did not clear the code, will do tomorow. Will this POS machine not agitate or spin if the problem was fixed, but code was not cleared?
[user=60379]tech1911[/user] wrote:
... Will this POS machine not agitate or spin if the problem was fixed, but code was not cleared?
NOTES:
ERROR #
#4 The Motor continues to operate with this error.
#6 When a locked Rotor is detected, the Washer will sit idle for 15 seconds and retry.
If the Motor does not operate after 3 tries, the LED blinks 6 times.
#8 The Motor continues to operate at reduced performance levels.
#9 Maximum Spin speed is limited to 50 RPM.
Critical Errors, #1, #2, & #7, will prevent Inverter/Motor from operating.
To clear errors, disconnect power until a clicking sound is heard (approximately 15 seconds).
Open and close the Lid 5 or more times in any 12 second period within the first 30 seconds of power-up.
Errors will not clear if Washer is in either Agitate or Spin mode.
