Request for Jacuzzi Z112 service manual
  • dave42
  • RegUS_PatOff
  • appl.tech.29501
Can't find a manual, but may be able to help. What kind of problem are you having?
We had a problem that the pump only runs on low speed. The pump/motor was replaced and then the switch/sensor that is attached to heater was replaced. Seemed to be working fine, then after 2 days, the same problem recurred.
When tub is plugged in (110 V), the pump/jets run at low speed, and heater light is steady red. When we try to increase speed, the motor makes a humming sound, and the light on the GFCI plug goes off momentarily. The pump then continues to run at low speed. The circuitboard was replaced about 2 yrs ago. We noticed some tarnish on the contacts of the power plug and cleaned that off, but that did not help. Thanks.
I don't know if this info will help, but it's all I could find.
Jacuzzi Spa Electronic Control System Troubleshooting Guide G647000 7-95.pdf
Jacuzzi Electrical Section 7348000E 4-97.pdf
