Serial L22748851
  • Replies 5
  • RegUS_PatOff
  • appl.tech.29501
  • morezan
GE Kenmore 363.9711516
I can't find any parts listed at SearsPartsDirect,
although I found the 363.9711516 Owners Manual
what problem are you having ?
It's actually with the icemaker, GE WR30X0289. The shut off arm will no longer stick in the up position. I would have expected a tab on the outside casing, but there does not appear to be one. Nor is there anything inside the unit to indicate how the arm was held in place. So I'm looking for a parts blow up or service manual. Thanks for your help.
Mostly likely the housing itself is damaged (which is no longer available).
If you reremove the cover, screws, and plate you will see the damage. I believe the only parts that are still available are the 2 plastic gears on the front.
The IM6 is the replacement fot this icemaker
this Housing ?
click on picture $ 46
click on picture IM6 $ 100 (Rocker ON/OFF Switch)
click on picture $ 101   ? ?  (Slide Switch ON/OFF)
Yep that would be the housing, not sure why I'm showing NLA. At any rate ya need to open it up and verify the destruction....if you decide to replace I would go with the one in "REGS." Last picture..its and updated version.
