commercial dryer dexter
Unit starts but no gas valve operation...... 24 volts to valve.........want to install a Manometer on valve............. thanks.........
  • Replies 1
  • kdog
  • certified tech group 51
You need to locate and remove the plug on the inlet side of the valve where you can install the manometer stub and plug your hose on - you'll be measuring static pressure to the valve
