This oven is giving the F1 code on both sides of the clock.
thanks
  • Replies 1
  • RegUS_PatOff
  • micgla
F1- Alarm “System Watchdog Circuit”
The system will detect a failure in the internal watchdog element relay circuits and will activate a cancel feature.
F1 will be displayed in the time digits and will beep until the cancel button or another function is selected.
An F1 failure could be detected in cook or time of day mode.
With an F1 failure the ERC is picking up a command to supply heat without receiving an input from the membrane.
The watch dog circuit is designed to prevent this.
If the beep continues after pressing cancel check the main control (ERC)
Dacor Oven
CPTS/CPTD
 Wire Diagrams
 Field Service Bulletins
 Failure Codes
 Diagnostic Manual
 Parts
