I thought i needed the 690 manual but i misread the model number and its really the 680/F. Serial number is P1541352. The area i'm looking for is the water and ice thru the door feature on the refrigerator door. I can't find this in the 600 series manual. Are there different manuals or are they the same? Sorry for the confusion. thanks for your help and patience..
  • Replies 10
  • RegUS_PatOff
    5
  • micgla
    4
  • ey11428
  • catservices
did you check the 600-1 Addndm & PARTS.pdf manual ?
I went thru the manual (both). I am dumbfounded. I cannot find anything on diagnosing or removal of the water thru the door feature on the 680.
did you see the wiring diagtrams for the 680 ?
It looks like you'd have to test for the signals at the Ice Dispense Control Board
thanks, i'm trying to figure out how to get to that board and to be able to remove it.
It's part of the diagram # 132 Door Dispenser Assembly part # 4200960
as mentioned on PDF pages 158 & 159
4200960 Door Dispenser Assembly at RepairClinic.com
click on picture
You found it! Thanks so much. I appreciate your help
Where do I find the manual for the 680?  I'm looking for the wiring diagram.
Any help is appreicated
links PM'd
  • 1 month later...
Hello, could you please forward me manual for the 680/f as well?
thanks
links PM'd
Guest
This topic is now closed to further replies.
