 Could you please provide me with the service and parts manual for a sub zero 590? Thank you
  • Replies 6
  • RegUS_PatOff
  • cdr14
  • Roadking97007
  • dinnyf
link PM'd
thank you for the quick response
Is there such thing as a Sub Zero Troubleshooting guide?
My 590 Freezer ok
 but refrig , no fan, no compressor, no cold beer :X
  • 1 month later...
Roadking97007
I have a Sub-Zero 590 #M1358618, Nov 97, R134a.
Can you please send me a link to a pdf copy of the manual?
There are a few issues with the 590.
1:  I believe the drain line in the refrigerator is plugged and I need to clean it out.  Condensation is forming around the top of the refrigerator door and puddling in front of the unit on the hardwood floor. I cleaned the drain pan and it was dry when the last puddle happened.  What is the best way to clean the drains?
2:  The water dispenser has slowed and the flow sputters from time to time.  It also continues to drain the last of the flow after the chute door has closed.  What would you recommend replacing?
3:  Fan is noisy up top, rattling around as it spins.  Is that the freezer fan motor that needs to be replaced?
Thank you.
  • 2 weeks later...
Great site! My mother's 590 needs help. Would it be possible to get the links to all available 590 manuals?
Many thanks!
link PM'd
